Issues creating a service without annotations
lschier
Hi all,
i tried to create a Service following this example:
http://support.ptc.com/cs/help/thingworx_hc/thingworx_edge/index.jspx?id=javasdk_topics-c_javasdk_service_adding_definition&action=show
but somehow it does not work for me.
I am able to create Thing and Properties without annotations (Properties are also set correctly on the server), but when i try and copy the sxample code from the Documentation i encounter a problem.
I am able to see the Service in the "Browse Remote Services" section and i can also enter the parameters, but everytime i try to execute the Service i get this error:
Unable to Invoke Service Add on Simple1 : Service Handler For [Add] Does Not Exist On Thing [Simple1]
i know this error occurs when i try to test a service without saving but i did save it.
I created a simple thing which only sends a random int to my server.
See my Code for the SimpleTing1 here:
package com.tinkerforge;
import java.util.Random;
import com.thingworx.communications.client.ConnectedThingClient;
import com.thingworx.communications.client.things.VirtualThing;
import com.thingworx.metadata.FieldDefinition;
import com.thingworx.metadata.PropertyDefinition;
import com.thingworx.metadata.ServiceDefinition;
import com.thingworx.metadata.annotations.ThingworxServiceDefinition;
import com.thingworx.metadata.annotations.ThingworxServiceParameter;
import com.thingworx.metadata.annotations.ThingworxServiceResult;
import com.thingworx.metadata.collections.FieldDefinitionCollection;
import com.thingworx.types.BaseTypes;
import com.thingworx.types.collections.AspectCollection;
import com.thingworx.types.constants.Aspects;
import com.thingworx.types.constants.CommonPropertyNames;
import com.thingworx.types.constants.DataChangeType;
import com.thingworx.types.primitives.BooleanPrimitive;
import com.thingworx.types.primitives.IntegerPrimitive;
import com.thingworx.types.primitives.NumberPrimitive;
import com.thingworx.types.primitives.StringPrimitive;
public class SimpleThing extends VirtualThing implements Runnable  {
private static final long serialVersionUID = 1L;
public SimpleThing(String name, String description, ConnectedThingClient client) throws Exception {
    super(name, description, client);
  //Create the property definition with name, description, and baseType
  PropertyDefinition property1 = new PropertyDefinition(
     "Property1",
     "Description for Property1",
     BaseTypes.NUMBER);
  //Create an aspect collection to hold all of the different aspects
  AspectCollection aspects = new AspectCollection();
  //Add the dataChangeType aspect
  aspects.put(Aspects.ASPECT_DATACHANGETYPE,
  new StringPrimitive(DataChangeType.ALWAYS.name()));
  //Add the dataChangeThreshold aspect
  aspects.put(Aspects.ASPECT_DATACHANGETHRESHOLD, new NumberPrimitive(0.0));
  //Add the cacheTime aspect
  aspects.put(Aspects.ASPECT_CACHETIME, new IntegerPrimitive(-1));
  //Add the isPersistent aspect
  aspects.put(Aspects.ASPECT_ISPERSISTENT, new BooleanPrimitive(false));
  //Add the isReadOnly aspect
  aspects.put(Aspects.ASPECT_ISREADONLY, new BooleanPrimitive(false));
  //Add the pushType aspect
  aspects.put("pushType", new StringPrimitive(DataChangeType.ALWAYS.name()));
  //Add the defaultValue aspect
  aspects.put(Aspects.ASPECT_DEFAULTVALUE, new NumberPrimitive(2));
  //Set the aspects of the property definition
  property1.setAspects(aspects);
  //Add the property definition to the Virtual Thing
  this.defineProperty(property1);
  //Put this code in the constructor (or a method called from the constructor)
  ServiceDefinition serviceDef = new ServiceDefinition(
  "Add",
  "Add two numbers");
  FieldDefinitionCollection parameterFields =
      new FieldDefinitionCollection();
  parameterFields.addFieldDefinition(
  new FieldDefinition(
  "p1",
  "The first addend of the operation",
  BaseTypes.NUMBER)
  "p2",
  "The second addend of the operation",
  BaseTypes.NUMBER)
  FieldDefinition resultField = new FieldDefinition(
  CommonPropertyNames.PROP_RESULT,
  "The sum of the two parameters",
  BaseTypes.NUMBER);
  serviceDef.setParameters(parameterFields);
  serviceDef.setResultType(resultField);
  super.defineService(serviceDef);
  super.initialize();
  public Double Add(Double p1, Double p2) throws Exception {
       return p1 + p2;
  public void set(){
  try {
  setProperty("Property1",  randInt(10,700));
  System.out.println("Property for Simple Thing sent to Server");
  updateSubscribedProperties(1);
  } catch (Exception e) {
  e.printStackTrace();
  public static int randInt(int min, int max) {
  Random rand = new Random();
  int randomNum = rand.nextInt((max - min) + 1) + min;
  return randomNum;
  @Override
  public void processScanRequest() throws Exception {
  // Be sure to call the base classes scan request
  super.processScanRequest();
  // Execute the code for this simulation every scan
  this.set();
  @Override
  public void run() {
  try {
  this.getClient().shutdown();
  } catch (Exception x) {
Thanks for your help,
Lukas
hhsu1
2-Explorer
(To:lschier)
I have the issue, too.
Have any one can use?
