Issues in Expression Widget in TWX 8.4.
Sugumar_5656
Hello all,
Recently i have upgraded my TWX 8.3 to 8.4 version.
In which the expression widget it took 1 minute for each connection.
It is really checking my patience.
any updated regarding this.
how can i solve this problem ?
Also i found one more bug, single expression function which i used repeated two times in my mashup.
I have attached the image for your reference.
Thanks & Regars
Sugumar R
I have also seen same problem with expression widget.
It overwrites another expression with the same name you recently edited/created.
Seems not properly tested before release of ThingWorx 8.4.
No answer to the OP, but more info about the new Expression functionality in 8.4.
Do either of you use the "feature" that allows you to put jQuery in the Expression widget?  In my testing this doesn't seem to work anymore in 8.4.
Same thing I also observed, that the jQuery I had written in ThingWorx version  8.3 is no more working with ThingWorx 8.4 Data Helper Expression and Validator widget.
slangley
(To:SKPatel)
Hi all.
We have an internal case opened with R&D for issues with the Expression Widget.  There is currently no information regarding timeline for a fix.
--Sharon
