It's possible integrate a unity project with thingworx?
gmachado
If I develop some application in Unity and and other in the thingworx platform can I combine them ? Like sending information from the thingworx platform to the unity app.
Best Regards!
Gonçalo
1 ACCEPTED SOLUTION
dupatel
(To:gmachado)
Gonçalo Machado​:It will be good if you can provide more insight on your use case and details for better understanding of your query. I believe you can send data from ThingWorx via Rest calls which can be consumed in your Unity application using SDK code.
-Durgesh
5 REPLIES 5
dupatel
(To:gmachado)
-Durgesh
I don't have a use case right now but I'm thinking build a game or something interactive in unity but I also want to use some data from sensors that are connected with thingworx. I thought about that option but it's the only one? Connecting things with AR through thingworx studio it's very simple so I was thinking if it's possible upload a unity project to thingworx studio.
Gonçalo
dupatel
(To:gmachado)
Gonçalo Machado​: I believe you can use Unity or Vuforia SDK to work with ThingWorx Studio. It was not very clear from the subject of the  thread as it says ThingWorx.
You can check out the available Vuforia SDK and Unity Extension for your development work.
-Durgesh
Yes, I already have that SDK. I thought that like ThingWorx Studio has some connection with ThingWorx Composer maybe some Unity App could also connect with ThingWorx Composer.
Thanks!
dupatel
(To:gmachado)
Gonçalo Machado​: As per my knowledge we do not have a Unity app which directly connect with ThingWorx Composer.
-Durgesh
