Does Thingworx have any extensions to integrate JMS Connectors.
Best Regards,
ThingWorx by default does not have an extension for JMS systems.
I have created though, in the past, using the ThingWorx Extension SDK (which you should use to build such a plugin) an JMS ActiveMQ Extension.
It's really old, stored here: https://github.com/cbadici/thingworx-activemqjms-extension
Obviously, not supported by PTC (and by anyone), but the source inside is very useful if you're trying to build such an Extension.
Hi Vladimir,
Thanks for sharing your build. Will check the repository.
Thanks and regards.
