JSON to Infotable
rmasoud1
JSON to Infotable
I ma trying to turn my JSON into an infotable. The JSON is being pushed to a propety of a thing in Thingworx from a java code. I am not sure how to go about this as all the questions I have seen are creating the json in the script. I want to place the table into a grid on a mashup.
Thank you
Links are not found!!
Hi Raj, there must be something in the community that blocked the links, sorry for that. Here I will attach the KCS number here directly, please check if they are helpful.
  • Convert JSON to an InfoTable   CS179012
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS179012&posno=1&q=Convert%20JSON%20to%20an%20InfoTable&source=…
  • Convert XML to InfoTable or DataTable   CS218242
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS218242&posno=1&q=Convert%20XML%20into%20an%20InfoTable%20or%2…
Ryan Yuan​ Thanks!!
jamesm1
(To:rmasoud1)
You might also like to try out this extension from the Marketplace which will translate JSON objects into InfoTables:
https://marketplace.thingworx.com/tools/Parsley_Extension
There is also another way you can do this purely within a JavaScript service if you have a datashape and you have an array of objects that matches that datashape. Here is how you can create a JSON representation of an InfoTable and then use the FromJSON snippet to transform it into a native InfoTable type:
//How to create an infotable from pure JSON
//create the JSON object to represent your infotable
var json = new Object();
//add the datashape definition
//this needs to be the correct datashape for your rows, in my example this is just a datahsape with a single string field called id
json.dataShape = DataShapes["DataShapeName"].GetDataShapeMetadataAsJSON();
//create a rows array
json.rows = [];
//add each row as an object
var row = new Object();
row.id = "idValue";
json.rows.push(row);
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].FromJSON({json: json});
