Java SDK - How can I pass a function call to ValueCollection
AymericR
3-Newcomer
I am using the Java SDK to invoke service QueryImplementingThingsOptimized
let result = ThingTemplates["LoraDeviceGenericModel"].QueryImplementingThingsOptimized(
    maxItems: 1000,
The corresponding Java code is as follows;
ValueCollection getEntityListParams = new ValueCollection();
getEntityListParams.SetNumberValue("maxItems", BATCH_THINGS);
getEntityListParams.SetNumberValue("offset", offset);
InfoTable queryResult = thingClient.invokeService(ThingTemplates, "LoraDeviceGenericModel", "QueryImplementingThingsOptimized",
getEntityListParams, TIMEOUT_30_000_MS);
But this call could be optimized by using a filter on returned fields;
function entityList(inarray) {
let out = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({ dataShapeName: 'EntityList' });
inarray.forEach(entry => out.AddRow({ name: entry, description: entry }));
return out;
maxItems: 1000,
basicPropertyNames: entityList(['name']),
propertyNames:entityList(['name'])
My Question is how can I do this via the Java SDK.
How do I need to populate the ValueCollection to set the  basicPropertyNames and propertyNames entries?
try to use follwoing code and appropriate values as parameters. Tried with Thingworx SDK 9.5
ThingTemplate genericThingTemplate = (ThingTemplate) EntityUtilities.findEntity("GenericThing", ThingworxRelationshipTypes.ThingTemplate);
       InfoTable data = genericThingTemplate.QueryImplementingThingsOptimized(1000, , nameMask, query, withPermissions, basicPropertyNames, propertyNames, networkName, networkParentNode, networkMaxDepth, offset);
slangley
(To:AymericR)
Hi @AymericR
It appears you may have received a solution to your problem.  If so, please mark the response as the Accepted Solution for the benefit of others in the community.
--Sharon
