Java SDK property buffer size
manasvi
In java sdk, if I set a property more than 100 times and then call updatesubscribedproperties, lets say 200 times.
I observe that only 100 values are sent to the server.
I assume there must be some buffer size/ stack size which determines this depth of stack.
Is there a way I can increase the "buffer" size to more than 100 ?
-Manas
2 REPLIES 2
slangley
23-Emerald II
(To:manasvi)
Hi @manasvi.
It looks like you've entered a case for this.  Please post the solution here once you have resolved it.
--Sharon
manasvi
(To:slangley)
Sure, I would post the solution.
I am waiting for the resolution as well.
