Java exception
AC_9552412
11-Garnet
Java exception
Hello, I have the following error (JavaException: com.thingworx.common.exceptions.InvalidRequestException: Language preferences can be changed only by the user or an administrator ) when trying to change the language of a user. The service is in a thing for which all users have visibility but only the System user has permissions to run it. How can I solve it?
TonyZhang
(To:AC_9552412)
@AC_9552412
Are you trying to invoke a function called SetLanguagePreferences on user?
I tried calling this function in custom JS service with non-admin user and get the same error message except for not a JavaException (not sure how you are changing the user language exactly)
You will need to add the service executor to a system-defined user group: SecurityAdministrators to allow the user to access service SetLanguagePreferences.
See Help Center > Security Administrators Group section
2 REPLIES 2
PaiChung
22-Sapphire I
(To:AC_9552412)
The users themselves have the permission to change the language preference.
Is it the actual user who is invoking this for themselves or are you trying to set it for a user?
I haven't had to deal with this for a while, but if you are doing it with the actual user and running into this issue,
then I think you can safely assign 'users' to that specific service.
TonyZhang
(To:AC_9552412)
@AC_9552412
