Javascript accessing InfoTable: Use 'rows' or not?
DanWolf
Say I have an InfoTable called searchResults.  I just realized that searchResults.length returns the same as searchResults.rows.length and I can access the row data in a loop using searchResults.rows[i].fieldname or just searchResults[i].fieldname.  What is the difference, if any, and has it always worked this way?  I'm using 8.5.1, not sure it works like this in other releases.
As far as I know, it is ok to call values from infotables in both ways. The difference is in notation.
Best regards,
Raluca Edu
Best regards,
Raluca Edu
DanWolf
(To:raluca_edu)
Thanks!
In addition, below is a table that demonstrates InfoTable helper functions versus manipulating the .rows array directly:
Best regards,
Raluca Edu
