KMZ/KML files in Google Maps widget
lorenmc
Is there a way to add KMZ/KML files to the Google Maps widget?
Loren
7 REPLIES 7
emoreira
(To:lorenmc)
Hi Loren,
I modified the Google Maps Extension to read KML files, using as reference the link below:
https://developers.google.com/maps/documentation/javascript/examples/layer-kml
I now have a parameter where I can reference a KML file.
Please let me know if you want some help.
If you don't mind helping me that would be great!  Are you able to just send me your updated extension?
Loren
emoreira
(To:lorenmc)
 Hi Loren,
You can get if from here: https://dl.dropboxusercontent.com/u/56013581/GoogleWidgets_ExtensionPackage_KML.zip
Using it is very straight forward: just add an URL for the KML file in the Widget property and it should show the layer with the routs or markups.
Unfortunately I am not generating a KML file yet but you can find many tools online that do that.
After importing the extension package should there be a new widget or will the original "Google Map" widget just be modified?
emoreira
(To:lorenmc)
The original will be modified
After a successful import of the extension I still can't find the property of the Google Map widget that will allow me to point to the URL of a KML file. Do you recall what the property is called?
Loren
emoreira
(To:lorenmc)
Hi Loren, I should not have called it a property. It is  a parameter in the IDE called KMLFile. See a screenshot.
https://dl.dropboxusercontent.com/u/56013581/kmlfile.jpg
Sorry for the confusion.
