Hi all,
i am wondering if there is a way to only activate the background-color for this widget only if the X value is appearing on the right side of the column.
Hello @TI_10203859 ,
I assume this is not part of ThingWorx functionality. Refer below link for your reference:
https://www.ptc.com/en/support/article/cs347365
Regards
Bhawna
if it is Advanced Grid, you can achieve with State Formatting. Please refer Styling the Grid and Applying State Formatting
Hi @TI_10203859,
Did you find Satish's response helpful? If you are still having issues, please provide the ThingWorx version and grid widget that you are using, so we can test it.
Aditya
Regards
Bhawna
