Label chart loading icon not showing properly Twx(9.3)
Abhi10217691
How can this problem be fixed when a different input is entered into the drop-down widget label chart and the loading icon only appears for 1 second while the prior data continues to display and the loading icon is hidden, after  some time new data gets loaded.
slangley
(To:Abhi10217691)
Hi @AJ_10217691.
Have you tried replacing it with one of the newer chart widgets?  Does the same issue occur with a non-legacy chart widget?
--Sharon
