How can this problem be fixed when a different input is entered into the drop-down widget label chart and the loading icon only appears for 1 second while the prior data continues to display and the loading icon is hidden, after some time new data gets loaded.
Hi @AJ_10217691.
Have you tried replacing it with one of the newer chart widgets? Does the same issue occur with a non-legacy chart widget?
Regards.
--Sharon
