Legend Color and Line Color are not matching the LineChart
pshashipreetham
18-Opal
As shown below, Tank-108 is selected, which has the Legend color Blue, but as per the LineChart, it is showing Pink.
As you saw below Screenshot, the Legends colors are duplicated if the NumberOfSeries Property in the LineChart Widget is set to Auto
Thingworx Version: 9.3.2
Shashi.
Shashi Preetham,
+91 8099838001 | shashi@psptechhub.com,
PSPTechHub  ||  World of PTC Thingworx  ||  LinkedIn
@PEHOWE ,
You are right to a certain point, instead of removing the Specification color in the data  provided, we removed the default color assigned to the Series in the Style Properties of the Chart, that solved the issue. Due to Default color assigned to chart, there was a duplicity in the colors.
Shashi Preetham,
6 REPLIES 6
Hello @pshashipreetham,
Have you reviewed Article - CS341203 - Data line rendered in Line Chart widget doesn’t match the color of its corresponding legend under particular data condition in ThingWorx Platform
The description seems to be on point with the issue you describe.
Let me know what you find.
Hi @PEHOWE ,
The issue is similar, but as per the Article, that was corrected 9.2, but isn't should be corrected in 9.3.2(Which my team is using) ?
Shashi.
Shashi Preetham,
@Shashi_Preetham,
Are you trying to specify the color?  If you are specifying the color with your configuration, I will need to retest the issue.
Peter
@PEHOWE ,
Yes, trying to specify color, if the legend shows one color and in the Chart the line of another color, that will cause much confusion to the user/client.
Shashi.
Shashi Preetham,
@Shashi_Preetham
If you remove all the color specification from the data being provided to the chart. Does the chart draw with a single color for each item?
I will see if I can get a test case and review the issue.
@PEHOWE ,
Shashi Preetham,
