Is it possible to make legends look like legends in the attached file
I did Legend as in the following screenshot:
I just applied my style to ChartLegendStyle from StyleProperties of the chart, no custom CSS done.
Hope it helps,
Raluca Edu
Hi @krishnakomal123.
Can you clarify which aspects of the legend you are specifically looking for? Is it positioning, colors, styles, etc.?
--Sharon
It should look just as it is in the image.Could you please try on it?
Not yet resolved
We haven't found a way to make the legend appear exactly as it appears in your image, which is why we were asking for clarification of your needs.
--Sharon
To what extent it can be done?I am able to figure out colors part but can you help me on look-wise?Size of rectangle should be more,dotted lines of legend etc
Could you please provide update on this?
Hope it helps,
Raluca Edu
