I have deployed ThingWorx war file but licence file is not created inside Thingworx Platform folder. I have followed this document for license. Please suggest.
https://support.ptc.com/lm/ThingWorx_Navigate_8.1_Licensing_Instructions.pdf
Isha,
I took a look at the application log, and seeing errors around connecting to your persistence provider (backend database for ThingWorx).
Have you modified your platform-settings.json file with the required parameters to upgrade from a previous version to 8.4?
You can read more about what needs to be done here: HelpCenter - Install/Upgrade ThingWorx on Windows
Neel
Did you get a text file generated in your ThingworxPlatform folder? Could you please attach your ApplicationLog.log file found in ThingworxStorage/logs?
Isha,
Neel
Hi @isha.
If you have previously deployed ThingWorx on the same machine, the licenseRequestFile.txt may not get generated. However, you can review the ApplicationLog.log located in \ThingworxStorage\logs for the Device ID needed to generate the license file.
--Sharon
Hi @isha.
Are you still having issues with licensing? If so, please provide a current set of logs from \ThingworxStorage\logs for further review.
If you have resolved the problem, please post the solution here for the benefit of others on the community.
--Sharon
