Greetings to All,
I'm trying to create a mashup where, using a collection, I can mini mashups of multiple things using the same template. I was able to do this with the GetImplementingThingsWithData service for that template.
My issue is to limit what is displayed based on the user login. And I don't just mean making it not visible, thereby creating blank spaces. I know I can do this by creating templates and mashups for different users, but I figure there has to be a simpler way to do this without the extra work.
Thanks for your help.
Could you try creating a custom service that checks the logic for current session/user info?
Yes. That did it. Thank you posipova. I am stilling learning to make use of the API calls and services that ThingWorx provides.
I created a service to make an InfoTable using GetImplementingThingsWithData. I then browse each row of the InfoTable to determine if the UserID value of each row matches the User Logged on. If it does not match, I delete the row. Below is a copy of my code if anyone is interested.
var things = ThingTemplates["Device_Template"].GetImplementingThingsWithData();
var qty = things.getLength();
for (var x=0; x < qty; x++) {
var row = things.getRow(x);
if (row.getValue("UserID") != ID) {
things.RemoveRow(x);
x = x - 1;
var result = things;
