Limit font type and language input
SOLVED
Highlighted
Hi I'm Thingworx Manager
I try to make Thing's name or attribute through service.
Is it possible to restrict the input language to English or limit it to numbers using a widget called textbox or other function in mashup?
Tags (1)
1 ACCEPTED SOLUTION
Highlighted
Re: Limit font type and language input
Hi seonho Cha​,
Per my understanding you can use Regex and allow only a-zA-Z0-9 in your JavaScript code.
Ankit Gupta
6 REPLIES 6
Highlighted
Hi seonho Cha​,
Ankit Gupta
Highlighted
Thanks Ankit Gupta
Highlighted
can you help me please?
can possible access thingworx composer page via appKey?
Highlighted
Hi seonho Cha​,
I have tried it for Mashups with URL like http://localhost/Thingworx/Mashups/<MASHUP>?appKey= b101903d-af6f-43ae-9ad8-0e8c604141af&x-thingworx-session=true
You can try similarly for Composer.
I hope it helps.
Ankit Gupta
Highlighted
What does you mean about restricting the input language to English?
To limit input to numbers you must use Numeric Entry widget.
Highlighted
Thanks Carles Coll
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
