Limit font type and language input
CHASEONHO
18-Opal
Hi I'm Thingworx Manager
I try to make Thing's name or attribute through service.
Is it possible to restrict the input language to English or limit it to numbers using a widget called textbox or other function in mashup?
Hi seonho Cha​,
Per my understanding you can use Regex and allow only a-zA-Z0-9 in your JavaScript code.
Ankit Gupta
6 REPLIES 6
Hi seonho Cha​,
Ankit Gupta
Thanks Ankit Gupta
can you help me please?
can possible access thingworx composer page via appKey?
Hi seonho Cha​,
I have tried it for Mashups with URL like http://localhost/Thingworx/Mashups/<MASHUP>?appKey= b101903d-af6f-43ae-9ad8-0e8c604141af&x-thingworx-session=true
You can try similarly for Composer.
I hope it helps.
Ankit Gupta
What does you mean about restricting the input language to English?
To limit input to numbers you must use Numeric Entry widget.
Thanks Carles Coll
