Limmit the postgre tablespace capacity
kpark1
Can I limmit the postgre tablespace capacity?
supandey
(To:kpark1)
Hi Kiyong, could you please share bit more detail around this requirement? If PostgreSQL is your default persistence provider and if you'd limit the disk size for it's schema your ThingWorx platform could get negatively affected. In sense that it may stop creating entities, or you'd not be able to log any data to the value stream / Stream
kpark1
(To:kpark1)
Thank you for your reply.
My default persistence provider is PostgreSQL and  I would like to limit the disk size regardless of getting negatively affected.
Could you tell me the detail method that limit the disk size?
kpark1
(To:kpark1)
Or I want to know how I limit the ThingworxPostgresqlStorage.
supandey
(To:kpark1)
I think this might of some help to you, but i would strongly recommend against it as you'd see in the discussion in this link as well. Database Size Limiting - PostgreSQL Database
