Line Chart Hover Value - customize
LP_10027711
Hello, i have the following Line Chart and would like to custom the hover value to only show "Value & ShortDate". So example "SP: 45, 11:52AM, 03/28/2022" or something like that.
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711
The fix for this issue is available in ThingWorx 9.3.3, which was recently released.
Once you have time to upgrade, please let the community know if it resolved your issue.
Regards.
--Sharon
7 REPLIES 7
I am upgrading to v 9.3 to allow custom tooltip values.
sbt
(To:LP_10027711)
Upgrading to 9.3 allows to have custom tooltip.
How can we change the format ?? ex ${label}, ${series}: ${value} shows Label and time with value. But to show time in specific format what modifications to be done??
do we have something like ${label}, ${series}.Format(HH:MM:SS): ${value} .Round(2decimals)
Any help would be appreciated!!
slangley
23-Emerald II
(To:sbt)
Hi @LP_10027711 & @sbt.
We have an internal case open on this and will provide more information as it becomes available.
Regards.
--Sharon
sbt
(To:slangley)
@slangley
Any alternative method that you you would suggest?? Like is there a way where i can modify the source output datetime format such that we avoid timezone etc..
Sunay
slangley
23-Emerald II
(To:sbt)
Hi @sbt.
Not at this point in time.  We'll let you know more as the internal case is worked.
Regards.
--Sharon
slangley
23-Emerald II
(To:LP_10027711)
Hi @LP_10027711
Regards.
--Sharon
sbt
(To:slangley)
Its resolved with 9.3.3
