Line Chart Y-axis is not autoscaling
RK_0705
Hi Team,
The Y axis of line chart in ThingWorx 9.2 is not auto-scaling even Y axis maximum is set on Auto.
The use case is that we need to autoscale the y axis as per the referenceline1value property of line chart. Actually when the value of reference line is either less than or greater than the values displaying on Y-axis of graph then it is not visible as the Y-axis is not auto-scaling with respect to the referenceline1value property.
Thanks in advance.
Hello @RK_0705
I have checked that autoscaling property is only available in Label Chart Widget. But as mentioned by @VladimirN , You can reach out to PTC support team and report this issue.
Bhawna
VladimirN
24-Ruby II
(To:RK_0705)
Hello @RK_0705
Bhawna
slangley
(To:bchaudhary)
Hi @RK_0705
For requesting functionality that does not currently exist, it is requested that you post a suggestion on the ThingWorx Ideas board.  By doing so, allows others to vote for its inclusion in a future release, thereby improving its chances of consideration.
--Sharon
