Line feed code in confirmation message
Yoshihiko.N
Dear Developers,
I'm trying to add a line feed code into string which will be displayed as a confirmation message.
I currently use "\n" as a line feed code as show the below though, it doesnt work.
Could you let me know on how to get it work normal ?
kazunari
(To:Yoshihiko.N)
Unfortunately, it also can't break lines in Message Text. Creating a new static mashup(with mashup parameter) and set that mashup on Navigation with modal popup would be the best way in your case. I hope this helps you.
kazunari
(To:Yoshihiko.N)
I assume you are using label widget, however it depends on the size of the widget and we can't break a line manually in label widget.
How about splitting the label and service into two parts?
Yoshihiko.N
(To:kazunari)
Hi Kazunari,
Thank you for your reply.
I'm using confirmation function like the below not label widget.
I created a servive to generate message text and I'd like to break lines manually in the message text.
kazunari
(To:Yoshihiko.N)
