List DropDown and Textbox Widget issue
pshashipreetham
18-Opal
I am giving an output of the Textbox and the Dropdown to a Service, based on the input the operations are performed in the service.
Issue:
How Can I know if there is nothing entered in the Textbox or Dropdown.
if(Textbox==="" || Dropdown === "")
//Do Nothing
else
//Do Operations
But always the it's going in to the if condition only.
How Can I check if the INPUT of the Widgets(Textbox and Dropdown) is Empty(no input given) or not
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
This issue is solved by following Code Snippet:
if(!Textbox || !Dropdown)
//Do Nothing
else
//Do Operations
The '!' checks for null, undefined and empty string.
Shashi
Shashi Preetham,
5 REPLIES 5
can you try this from JS service and first test it from composer directly? you can take 2 service inputs as TextBoxInput type string and DropDownInput as type string. You can check the logger in script logs, please make sure script log logging level is warn or above.
if(TextBoxInput==null || DropDownInput==null)
logger.warn("either text box or drop down is empty");
else
logger.warn("Atleast there is a value");
Hi @mnarang
This is the first option I have tried, but this doesn't work at all.
Thanks !!
Shashi Preetham,
May i know on which Thingworx build you are trying this? This is working fine on my TWX server(9.1).
suverma
(To:pshashipreetham)
Hi @pshashipreetham
You can also try modifying your service as:
if(TextboxInput == undefined || TextboxInput == "")
//Do Nothing
else
//Do Operations
//Do Nothing
else
//Do Operations
Shashi
Shashi Preetham,
