Hi All
I have a list of items in my mashup and a Time-Series Chart, i wish to achieve the following use-case
On selecting an option from the list, the chart should change values accordingly. For eg If there are 3 list items in a list, for every item there should a time series chart and upon selecting that option, chart corresponding to that list item should display
Same use-case I would want to achieve with a Progress Gauge
Regards
Ketan
Hello Ketan,
Depending further on your use case you can have something like a List Widget to allow your end user to make the desired selection (e.g. selecting option A, B or C). A service will be needed to feed the options into the List Widget in this case. You could then bind the Selected Row parameter of the option from the List to an input parameter on the data service that is feeding data into the Time Series Chart. Additionally to ensure the data in the Time Series Chart updates every time a user changes a selection in the List Widget you would want to bind the SelectedRowChanged action of the List service to the data service of the Time Series Chart.
I hope this makes sense and is sort of what you are looking for. If you are still unclear I could look into generating a simple example.
Hello Ketan,
Hi
I am clear about the approach, I did the same in my mashup but was not able to achieve the same.
If you could help with a small example it would be highly appreciated
Regards
Hello again,
Please find a very simple example attached. The Mashup to view the bindings and the Time Series Chart data is called ChartDataChange.
Hopefully this helps.
Hi
Thankyou for the examply. But is it a valid mashup because I am not able to import it in my Thingworx Composer
Regards
I just tested importing this into another one of my systems and I will able to import it successfully. Can you confirm the version of ThingWorx you are using? This example is from 8.5 using updated Widgets. Perhaps this is the issue.
Can you provide the error from the ApplicationLog to review?
Hi
We are using 8.3.3 at present and under ApplicationLogs it only gives the ServiceDefinition option
regards
Okay. I will work on a new example for older versions of ThingWorx.
Please find two files in the attached zip. One has the generated data for the Chart and the other are the necessary entities including the Mashup. This was generated using legacy Widgets in ThingWorx 8.4 and should work with your 8.3.3 instance.
Ensure that the entities are imported prior to the data.
Hi
Thankyou for the help I will import the files and get reference
Regards
Ketan
Hi @ketanaga.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
