List Of Application Keys and their expiration date
FredDL
I want to monitor the application keys and their expiration date
I tried two ways to list the application keys:
  • using GetEntityList() from EntityService
 var result = Resources["EntityServices"].GetEntityList({
  maxItems: 10000,
  nameMask: undefined,
  type: 'ApplicationKey',
But this give me an infotable with the following fields:
avatar, description, homeMashup, isSystemObject, name, tags
  • Then I tried SpotLightSearch:
const result = Resources["SearchFunctions"].SpotlightSearch({
maxItems: 1000000,
types: { items: [
"ApplicationKey"
aspects: { isSystemObject: false },
maxSearchItems: 1000000
This give me an infotable wtih the following fields:
 delete, description, id, isEditable, isEditableExtensionObject, isEditableSystemObject, isExtension, isSystemObject, lastModifiedDate, name, parentName, parentType, read, type, update
So my problem is that both returned infotable that are not matching the ApplicationKey DataShape.
And those infotable lack the userNameReference  field which could allow me to get the  ApplicationKeyExpirationInfoCollection (using GetApplicationKeyExpirationInfo
https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Composer/Security/ApplicationKeys/ApplicationKeyServices.html ) where I could have the reference user and expiration date.
How can I get a list of application key with their expiration date?
PaiChung
22-Sapphire I
(To:FredDL)
I think the second one provides 'name' from there can't you use ApplicationKeys[name].GetExpirationDate() ?
Beyond that here is another search function:
var params = {
maxItems: undefined /* NUMBER */,
searchExpression: "**" /* STRING */,
types:  { items: ["ApplicationKey"]} /* JSON */,
aspects: undefined /* JSON */,
excludedAspects: undefined /* JSON */,
maxSearchItems: undefined /* NUMBER */,
tags: undefined /* TAGS */
// result: INFOTABLE dataShape: EntityDescriptor
var result = Resources["SearchFunctions"].SearchModelEntities(params);
3 REPLIES 3
PaiChung
22-Sapphire I
(To:FredDL)
var params = {
FredDL
(To:PaiChung)
Thank you.
I thought that the search for the Applications Keys would return data with the Application Keys DataShape and not EntityDescripto (or else) but this seems logic afterwards
ApplicationKeys[name].GetExpirationDate() returns the expiration date that I need. So I will start from there!
Thanks.  Solved my issue as well.
