List Shuttle Widget add element multiple times to target list
M4RC
Hello folks,
i have a question to the list shuttle widget of thingworx 9.1.0. (Help Center)
Is it possible to add an item of the "source list" multiple times to the "target list"?
Currently the item from "source list" disappears as soon as I add it to the "target list".
I attached a screenshot with an example what i want.
Best regards
Marc
slangley
23-Emerald II
(To:M4RC)
Hi @M4RC
The widget is not designed to work the way you wish.
We're still not understanding your use case.  Why would you want the selections to appear multiple times after being selected?
--Sharon
4 REPLIES 4
slangley
23-Emerald II
(To:M4RC)
Hi @M4RC
Based on the behavior you describe, it sounds like it's working as intended.  What is your use case?
--Sharon
M4RC
(To:slangley)
sorry for the inaccurate description.
Currently the widget works in such a way that clicking on "Add" removes the item from the left side and adds it on the right side. (Note: currentFunction.png)
However, I would like to add one or more elements from the left side to the right side as many times as I want. (Note: example.png from initial post)
I could not find a setting to make this happen.
Best regards
Marc
slangley
23-Emerald II
(To:M4RC)
Hi @M4RC
--Sharon
M4RC
(To:slangley)
Hello, thanks for the answer.
Explicitly I wanted to use this widget for a screen rotation. But the added mashups can have different parameters. Thus, a mashup must be able to be added multiple times (to the right).
I used a workaround to recreate the functionality of the widget but with infinite "add" possibilities.
Best regards
Marc
