List Widget CSS customization not working
kthangapandy
3-Visitor
I need to customize List widget to reduce list-item min-height to 20px and reduce padding around item-checkbox to 3px.
I tried multiple attempts like one below to access the part(list-item) and part(item-checkbox). I could not find a solution.
.widget-ptcslist::part(list-item) {
min-height: 20px;
.widget-ptcslist::part(list-item-item-checkbox) {
padding: 3px;
Any solutions would be helpful.
1 ACCEPTED SOLUTION
Hi
Upon confirmation, the same CSS code is working in Thingworx 9.2, so if you can upgrade your Thingworx to 9.2 should be able to make it work.
8 REPLIES 8
I think the first one you tried is working fine. Perhaps you didn't notice the effect because of the RowHeight property of the list widget?  Try changing the value of min-height to a value greater than RowHeight.
         min-height: 20px;
For applying padding around checkbox of the list item (after enabling MultiSelect property of the List widget) .
Try below selectors to target the checkboxes.
.widget-ptcslist::part(item-checkbox) {
          padding: 30px;
.widget-ptcslist::part(item-checkbox)::part(root) {
          padding: 10px;
.widget-ptcslist::part(item-checkbox)::part(box) {
          margin-left: 7px;
Thanks for your response. I have updated the row height property and applied the CSS modifying the padding. Still no changes could be observed. Please find attached image where the padding has been highlighted. I would like to have padding to be 3px all sides.
[cid:image001.png@01D77199.9A9797C0]
Attached snapshot
Could you please share the ThingWorx version info and export the entity for me to replicate the issue?
The Thingworx Version is 9.1.3-b593.
Please find attached entities
Thanks for sharing the version info and entities. I can see the same CSS is working on Thingworx 8.5 but not on Thingworx 9.0 onwards including 9.1.3.
The difference I found in the HTML structure is that in Thingworx 8.5, ptcs-list-item element is enclosed in <div part="list-items-container"> </div>
whereas in Thingworx 9.1.3, the ptcs-list-item element is enclosed in <ptcs-v-scroller part="list-items-container"> </ptcs-v-scroller>
The issue might have to do with the nature of custom element list-items-container and need further research on how to style the child elements of list-items-container.
Hi
TonyZhang
(To:TonyZhang)
BTW the "root" part doesn't exist under the checkbox in Thingworx 9.2.
