List Widget as input and put list's data into another data table
xiaoqw
As Attached file below, I want to put DummyDataDatatable's data into DummyDataDuplicate. And Datashape is same. there are three types of widget: dropdown, textbox and numeric entry.
Now my process is:
1. I link dropdown list's value into textbox in DummyDataDatatable.
2. I drag textbox's data into DummyDataDuplicateDatatable's column SKU and ID also.
but after that, there is nothing in the DummyDataDuplicateDatatable.
Can Someone help me to figure it out?
Tracy
PaiChung
22-Sapphire I
(To:xiaoqw)
To Read/Write data from/into datatables you need to user services.
So to move the data, you would select data in one table, then write them to the other table, then do a re-read of the target table to show the new resulting content of that datatable.
PaiChung
22-Sapphire I
(To:xiaoqw)
xiaoqw
(To:PaiChung)
Hi can u show me an example for this method?
xiaoqw
(To:PaiChung)
Hi PaiChung, how to write them into other them in another datatable? that's the point I want to figure it out.
PaiChung
22-Sapphire I
(To:xiaoqw)
You use the standard services available with datatables
Get/Query DataTableEntries to retrieve Add or AddOrUpdateDataTableEntry to write
xiaoqw
(To:PaiChung)
Thank you. I figure it out alr.
