List of all System Objects in order to set permissions in a batch (script)
jacekgra
1-Newbie
Is there any way to obtain list of all SystemObjects that exists in Thingworx?
I would like to set specific permissions on all SystemObjects and I definetlly don't want to do it manually
1 ACCEPTED SOLUTION
Hi Jacek,
Maybe better you go with this service ( which should be faster than previous one ):
var result = Resources["SearchFunctions"].SpotlightSearch({
  maxItems: 1000000 ,
  types: { items: ["Thing",
                     "ThingShape",
                     "ThingTemplate",
                     "DataShape",
                     "Network",
                     "ModelTagVocabulary",
                     "Mashup",
                     "Menu",
                     "MediaEntity",
                     "StyleDefinition",
                     "StateDefinition",
                     "DataTagVocabulary",
                     "Group",
                     "User",
                     "ApplicationKey",
                     "Resource",
                     "Organization",
                     "Dashboard"
  aspects: { isSystemObject: true },
  maxSearchItems: 1000000
for each (row in result.rows) {
    // -- Do Whatever the the row.name entity
Pai Chung​ Can you update this article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS241962 with the above code, I think it's better.
Best Regards,
Carles
6 REPLIES 6
PaiChung
22-Sapphire I
(To:jacekgra)
Each Entity carries isSystemObject
You might be able to leverage one of the SearchFunctions and use that Property in conjunction.
This snippet might help:
var types = Resources["Tagger"].GetEntityTypes();
for (var x = 0; x < types.rows.length; x++) {
    var row = types.rows;
    var entities = Resources["EntityServices"].GetEntityList({type: row.name});
    for (var y = 0; y < entities.rows.length; y++) {
        var entity = entities.rows;
        if (entity.isSystemObject) {
            logger.info("System object : " + entity.name);
                      // Do whatever here
        } else {
            logger.info("Not a system object : " + entity.name);
Hello Sajid,
Unfortunatelly I do not have resource "Tagger" in my TWX 7.1. Is this something from older version or customization?
Hi Jacek,
  maxItems: 1000000 ,
                     "ThingShape",
                     "ThingTemplate",
                     "DataShape",
                     "Network",
                     "Mashup",
                     "Menu",
                     "MediaEntity",
                     "StyleDefinition",
                     "StateDefinition",
                     "Group",
                     "User",
                     "ApplicationKey",
                     "Resource",
                     "Organization",
                     "Dashboard"
Best Regards,
Carles
Thank you Carlos! It works as expected.
Yes, just realized that it is a customized resource. Anyways, Carles's answer is more generic.
