Hi All,
I'm trying to find a way to programmatically list all entity permissions for a specific user or user group in Thingworx 9.7?
I've already searched the PTC community and found these two threads, but they haven't resolved my issue.
Solved: Permisions for users and groups - PTC Community
Solved: Re: List a User's, Group's, or Org's Permissions - PTC Community
The main problem is that the CheckPermissionDataShape is missing in Thingworx 9.7. I attempted to create my own data shape with required fields based on the documentation, but it is not working as expected.
Does anyone know of an alternative method or a workaround to programmatically retrieve a list of all entity permissions for user or user group in Thingworx 9.7? Any guidance would be greatly appreciated!
Bhavya
Hi @Bhavya_PC,
"The main problem is that the CheckPermissionDataShape is missing in Thingworx 9.7."
↑ I don't think any thingworx version has an OOTB datashape named "CheckPermissionDataShape"; this is supposed to be a custom datashape.
What fields you wish to output as a result is dependent on your business needs. (If you review the step 2 of the reply: "2. Create a datashape that is used for listing the result of permission")
In the https://community.ptc.com/t5/ThingWorx-Developers/List-a-User-s-Group-s-or-Org-s-Permissions/m-p/732978#M52566 's example, each field (user, entity, PropertyRead etc.)'s value of the result infotable is set in the for loop
row.user=UserName;
row.entity=entities[i].name;
row.PropertyRead = ...;
row.PropertyWrite = ...;
row.serviceInvoke = ...;
row.EventInvoke = ...;
row.EventSubscribe = ...;
Best,
Hi @Bhavya_PC,
row.user=UserName;
Best,
Hello @Bhavya_PC,
It looks like you have a response from a support expert. If any of these replies helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
