I want to set localisation for value display. For example, I am showing a number in value display. When I select Hindi, the number should be displayed in Hindi. Is it possible?
With regards
Yedukrishnan U
There is no localization for Value display the way you want it to work.
You would have to create the value in the proper format Server side and send that to the Mashup.
You would have to treat everything as text though I think
