Localization tables not removed when removing an extension
rtaylor-3
Greetings,
I'm using Thingworx 6.5 and have an extension in which i include Localization tables.
I can import the extension and can subsequently see the localization tables under the System section.
If i remove the extension, these localization tables are no removed as well.
Is this expected behavior?
5 REPLIES 5
Aanjan
(To:rtaylor-3)
Robert, are these custom Localization Tables that come with the extension? If you delete an extension, it is recommended to restart Tomcat to completely remove any traces/ dependencies.
rtaylor-3
(To:Aanjan)
Yes...these are custom Localization Tables that we are importing with the extension.
Aanjan
(To:rtaylor-3)
Would it be possible for you to restart Tomcat and check if they're still present?
rtaylor-3
(To:Aanjan)
I bounced tomcat and the localization tables are still there.
Aanjan
(To:rtaylor-3)
Is this a custom extension or did you download from the Marketplace? Please do attach or add a link to download the extension if possible.
