Greetings,
I'm using Thingworx 6.5 and have an extension in which i include Localization tables.
I can import the extension and can subsequently see the localization tables under the System section.
If i remove the extension, these localization tables are no removed as well.
Is this expected behavior?
Robert, are these custom Localization Tables that come with the extension? If you delete an extension, it is recommended to restart Tomcat to completely remove any traces/ dependencies.
Yes...these are custom Localization Tables that we are importing with the extension.
Would it be possible for you to restart Tomcat and check if they're still present?
I bounced tomcat and the localization tables are still there.
Is this a custom extension or did you download from the Marketplace? Please do attach or add a link to download the extension if possible.
