LogUtilities and JUnit tests
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Greetings,
I'm trying to write a simple unit test for java ThingShape.
My code has a static initializer for the logger
Line 42: private static Logger logger = LogUtilities.getInstance().getApplicationLogger(PredictableAsset.class);
When i run the corresponding test class i'm getting an error:
java.lang.ExceptionInInitializerError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at javassist.runtime.Desc.getClassObject(Desc.java:43)
at javassist.runtime.Desc.getClassType(Desc.java:152)
at javassist.runtime.Desc.getType(Desc.java:122)
at javassist.runtime.Desc.getType(Desc.java:78)
at com.ptc.cslm.pa.common.entity.thingshape.PredictableAssetTest.setup(PredictableAssetTest.java:38)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.junit.internal.runners.MethodRoadie.runBefores(MethodRoadie.java:133)
at org.junit.internal.runners.MethodRoadie.runBeforesThenTestThenAfters(MethodRoadie.java:96)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl$PowerMockJUnit44MethodRunner.executeTest(PowerMockJUnit44RunnerDelegateImpl.java:294)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit47RunnerDelegateImpl$PowerMockJUnit47MethodRunner.executeTestInSuper(PowerMockJUnit47RunnerDelegateImpl.java:127)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit47RunnerDelegateImpl$PowerMockJUnit47MethodRunner.executeTest(PowerMockJUnit47RunnerDelegateImpl.java:82)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl$PowerMockJUnit44MethodRunner.runBeforesThenTestThenAfters(PowerMockJUnit44RunnerDelegateImpl.java:282)
at org.junit.internal.runners.MethodRoadie.runTest(MethodRoadie.java:87)
at org.junit.internal.runners.MethodRoadie.run(MethodRoadie.java:50)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl.invokeTestMethod(PowerMockJUnit44RunnerDelegateImpl.java:207)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl.runMethods(PowerMockJUnit44RunnerDelegateImpl.java:146)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl$1.run(PowerMockJUnit44RunnerDelegateImpl.java:120)
at org.junit.internal.runners.ClassRoadie.runUnprotected(ClassRoadie.java:34)
at org.junit.internal.runners.ClassRoadie.runProtected(ClassRoadie.java:44)
at org.powermock.modules.junit4.internal.impl.PowerMockJUnit44RunnerDelegateImpl.run(PowerMockJUnit44RunnerDelegateImpl.java:122)
at org.powermock.modules.junit4.common.internal.impl.JUnit4TestSuiteChunkerImpl.run(JUnit4TestSuiteChunkerImpl.java:106)
at org.powermock.modules.junit4.common.internal.impl.AbstractCommonPowerMockRunner.run(AbstractCommonPowerMockRunner.java:53)
at org.powermock.modules.junit4.PowerMockRunner.run(PowerMockRunner.java:59)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:459)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:675)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:382)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:192)
Caused by: java.lang.NullPointerException
at com.ptc.cslm.pa.common.entity.thingshape.PredictableAsset.<clinit>(PredictableAsset.java:42)
... 34 more
Has anyone else run into this. There is probably some magical annotation i need to add or worse, i have to mock the LogUtilities.
Any advice appreciated.
- Labels:
Extensions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ok...was working until the logger was actually invoked. Was getting a NPE.
Had to use the specific implementation of Logger for this to work.
@RunWith(PowerMockRunner.class)
@PrepareForTest({LogUtilities.class, EntityUtilities.class,ch.qos.logback.classic.Logger.class})
public class PredictableAssetTest {
PowerMock.mockStatic(LogUtilities.class);
LogUtilities lu = PowerMock.createMock(LogUtilities.class);
ch.qos.logback.classic.Logger logger = PowerMock.createMock(ch.qos.logback.classic.Logger.class);
EasyMock.expect(LogUtilities.getInstance()).andReturn(lu);
EasyMock.expect(lu.getApplicationLogger(PredictableAsset.class)).andReturn(logger);
PowerMock.replay(LogUtilities.class, lu);
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ugggh....Have to mock LogUtilities.
Then it works
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
