Logging with the .NET sdk?
  • July 8, 2016
  • 8 replies
  • 4363 views
I'm trying to figure out how to log using the .NET SDK so far the only decent reference I came across is this link below:
.NET SDK Logging Configuration
However when I add this information to the App.config file (part of the file in the link above) I get several different exceptions. If I remove these then it'll compile but then there is no Log file/directory created. (If it is I can't find it anywhere)
<source name="com.thingworx.communications.client.TwApiWrapper" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.communications.client.ConnectedThingClient" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.communications.client.things.VirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
Hope someone can help!
Best answer by jbennett1
Hi guys,
Thanks for your replies, I've managed to figure out the correct App.Configuration code:
<?xml version="1.0" encoding="utf-8"?>
<configuration>
  <system.diagnostics>
    <sources>
  <source name="com.thingworx.common.utils.JSONUtilities" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.communications.client.BaseClient" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.communications.client.things.contentloader.ContentLoaderVirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.communications.client.things.filetransfer.FileTransferVirtualThing" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
        <source name="com.thingworx.metadata.annotations.MetadataAnnotationParser" switchName="SourceSwitch" switchType="System.Diagnostics.SourceSwitch" >
          <listeners>
            <add name="file" />
          </listeners>
        </source>
</sources>
<switches>
  <add name="SourceSwitch" value="Verbose" />
  </switches>
  <sharedListeners>
    <add name="file" type="com.thingworx.common.logging.FixedFieldTraceListener, thingworx-dotnet-common, Version=5.6.1.1100, Culture=neutral"/>
  </sharedListeners>
  <trace autoflush="true" indentsize="4" />
</system.diagnostics>
</configuration>
Not sure why it didn't like the last line PublicKeyToken=null" initializeData="false" ​but all is working now.
Hopefully this is useful to someone else.
John
What are the exceptions that you are seeing when you add the configuration given in that Community post?
Thanks!
Tori
jbennett11-VisitorAuthor
Hi Tori,
Hope all is well!, this is first point it breaks!
Kind regards
John
Hi John, if you cannot connect the .NET SDK to the ThingWorx platform you can disable encryption as explained on the .NET SDK Developers Guide (page 20).
client.DisableEncryption(); // replace this line from .NET Dev Guide with one of the below lines.
BaseClient.disableEncryption(); // OR
ConnectedThingClient.disableEncryption();
Let me know if this helps.
John,
If you use the entire app.config file provided in the example you linked in your original post do you still see the same errors?
Meghan
jbennett11-VisitorAuthorAnswer
Hi guys,
<configuration>
    <sources>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
          <listeners>
            <add name="file" />
          </listeners>
        </source>
</sources>
<switches>
  </switches>
  <sharedListeners>
  </sharedListeners>
</configuration>
John
