While Trying to Upload MQTT Extension in ThingWorx Composer it is failing.
Error : Error importing: error: Not Acceptable - [package: MQTT_Extensions, error: ERROR - trying to remove uploaded Extension Package contents for [MQTT_Extensions]: ExtensionPackage MQTT_Extensions Does Not Exist]
Hi Gaurav,
Are you running the latest version of ThingWorx (4.2 SP1) and using the latest extensions from the Community site? If you're unsure about either, I recommend downloading the latest version of ThingWorx and the MQTT extension from the
Downloads
section. If you just need the latest version of the MQTT extension, you'll likely need to start from a fresh install of ThingWorx and then install the extension.Thanks,
Adam
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
