MQTT Subscriber things can't trigger subscription
XZ_10149535
Hello, have you solved the problem? I have also encountered the same problem
DanZ
(To:XZ_10149535)
What are the error messages in the Script Log and/or Application Log?
jbester
(To:jbester)
Hi @XZ_10149535
In my experience, the issue is usually around permissions for the "System" user (used by default as the user that updates the property) for event execute/subscribe. You will have an issue for the subscription firing and if the property is logged to store it to the value stream.
But it is just a guess, the logs would provide a more clear direction to the root cause.
Kind regards,
