MQTT Subscriber things can't trigger subscription
Hi all
I'm create a Things based on MQTT Subcriber and connect to MQTT broker. i'm using subcription on this Things with datachange events.
When i'm change properties value with mqtt broker, the subcription is not triggered. But when i'm use UI change value, the subcription still work.
I'm changed Properties Data Change Type from Value to Alway. And I have set visibility to ThingworxPeristentProvider for System User by reading similar topics but the situation is not changed.
P/S: I'm create a Things based on MQTT (combine connection and subcriber), it's still work.
Please support me, thanks.
