Hi All, I am new to thingworx and trying to complete the Arduino Uno weather app from the tutorial provided on the following link:
Weather App with Arduino Uno | ThingWorx
I am using a developer account and ThingWorx Composer 6.0. I am stuck at the following part of tutorial:
The step I am getting stuck on is where I have to create a Notification Thing and look for MailServer Thing Template.
I simply can't find MailServer Thing Template.
Any suggestions or inputs?
Dinesh
Hi Dinesh,
You may not have it already imported on your ThingWorx instance. Download it from thingworx market place http://marketplace.thingworx.com/downloads/mail/ and import it by going in your ThingWorx Composer to Import/Export --> Extensions --> Import.
Afterwards you should be able to find it among your templates when creating a new Thing.
Veronica
hello
I'm have a similar problem with MailServer - this time for Android App. The place on the net you point to Veronica is full of things, but hard to find the MailServer Ting Template there.
Greetings Georg
Hi Georg,
Indeed the link seems to have changed. This is the update one
http://marketplace.thingworx.com/Items/mail-extension
Thank you,
Veronica
Hey Veronica
Yes, I actually found the material, but don't find any MailServer Thing Template. Do I have to create it myself from the downloaded files? And if so - should I know how to do just that?
Greetings Georg
Hi Georg,
Did you import the Mail extension on your thingworx instance and still cannot find the MailServer Template when creating a new Thing ?
Thank you,
Veronica
hello Veronica
Yes, I did. You can see the stuff on pictures attached: A Lib of jar-files and a XML-file:meta-data.
following I tried to import e.g. thingworx-mai-extenson into the Android Things, but without success. I don't know what to do with those files?
Greetings Georg
I downloaded mail extension from http://marketplace.thingworx.com/Items/mail-extension
But it failed with a error "
| Mail_Extensions2.0.0 | Extension : Mail_Extensions:2.0.0 does not comply with ThingWorx extension versioning requirements |
Can any one help me with mail extension. I am not getting to access from the market place.
It shows error..
Tushar Ghosh: Can you try ThingWorx IoT Marketplace and see if this URL works for you ?
-Durgesh
