Hi All,
I used State formatting on data chart for implement 2 threshold level LOW and HIGHT.
The two threshold level LOW and HIGHT as properties of Thing, but inside the Configure State Formatting is impossibile to use property name .
How can I do to use properties name to define a State formatting ?
Many Thanks
BR
Dimitri
once you have applied the state based formatting, you'll see new Properties on your Widget, should be called State_Lo/State_Normal that you can now bind your properties to
