Mashup Based Off Resolution Size
victorgan
Is it possible to change the layout/widgets of the mashup depending on the resolution size?
Thanks.
3 REPLIES 3
Does anyone have any thoughts around this?
Thanks.
You want to change whole layouts/widgets depending on the resolution size? If that is the case, this is not currently possible. However, many of the widgets are "responsive," so they will resize depending on the resolution.
– Adam
Hi Adam,
Thanks for the reply. Yes, I wanted to know if say tabs within a mashup that would be displayed on a desktop could be converted to a dropdown when the resolution size was of an phone, etc.
Thanks again for the confirmation!
