Hi !
I'm a newbie to use thingworx and I have a question about Label in responsive design. When I want to add them to my panel in an responsive containers they come static so when I resize my windows they keep the same size... Not responsive at all, too bad cause all my other widget are
Any idea guys ? ^^
Guillaume
Hi Guillaume,
Label it's not a responsive Widget, you should use Value Display if you want a Responsive Label.
Carles.
Hi Guillaume,
Carles.
It's work perfectly with ValueDisplay, sorry not saw it by myself But when I use a valuedisplay, the size of the font stay the same when I resize the windows ...
Anyways, thanks a lot Carles !
Hi Guillaume,
You don't have this kind of responsive ( grow font size when window grows size ).
Carles
