Hi Gurus,
After watching the webcasts for mashup design I have gone back and started making some changes like panel on panel for alignment. For some reason I keep getting the vertical scroll bar even when the resolution is high enough.
does anybody have any suggestions?
Please have a look at the image below to see what I am talking about.
Bryan
Panels have a HideScrollbars property ;)
Yep i know. The problem with that is if the resolution changes to smaller you cant scroll....
Is that the only way?
Out of the box I think so.
