Hi
I had upgraded to ThingWorx 9. I have imported entities from older ThingWorx 7.2. Now when i opened Mashup in Composer it keeps on loading with Warning Message that Mashup has deprecated widgets. I can upgrade them.
Initially i did not want to that, so i cancelled the upgrade. Mashup keeps on loading forever.
Then next time i did upgrade, i can see widget list upgraded with new widgets but still Mashup screen keeps on loading and never opens up.
Note: I was able to open other Mashups.
Any pointers on what i can look into for more information. I do not see any specific error in Application log.
I was using Label/Text Box/ Check Box/ Radio button on that page.
Regards
Vaibhav
i re-imported mashup with deprecated widgets and did not resolve the conflict for upgrade . It worked. Closing issue for now.
Have the troubleshoot or the developer window open in your browser as you load the mashup, it will show what it is trying to do.
I checked but in network tab no request fails. Is their anything specific i need to look for.
Just FYI: i have warning i18n support is missing for the string "A bindable event triggered when the SelectedText for this widget is modified" but nothing else
