Mashup resolution
krishnakomal123
Mashup resolution
I have designed screen in 1680 *1050 resolution.It is looking perfect only in that resolution.Below is the attached application screenshots in different resolutions.No matter how much ever I try avoiding panels still i had to use them to meet design requirements.How do I design a fully responsive UI with no issues?
Hi @krishnakomal123.
Support for ThingWorx 8.3 is being dropped this month, so it's recommended that you upgrade to a supported version.  Note, however, that ThingWorx 9.0 is targeted for release in late June/early July.
--Sharon
4 REPLIES 4
Which version of ThingWorx are you running?  Newer versions of the platform make use of responsive containers with additional sizing parameters.
--Sharon
8.3.3
--Sharon
slangley
23-Emerald II
(To:slangley)
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Note that ThingWorx 9.0 has just released.  Support for ThingWorx 8.3 ended on June 8.
--Sharon
