Mashups data configuration
Telles
Hi,Team.
  In this trainning:
https://developer.thingworx.com/en/resources/learning-paths/getting-started-on-thingworx-platform/thingworx-foundation-quickstart/display-device-data
I can´t configurate the DATA GAUGE and DATA LINE CHART, like this pic.
I started the trainning couple times, and do step by step carefully.
How I can config correctly?
I´m using VM 12.0.2.
Regards.
Telles.
Your screen shot shows an old version of ThingWorx. The guides are updated to use the latest version of ThingWorx which is available both as a download or a PTC Cloud hosted trial:
https://developer.thingworx.com/en/resources/trials
7 REPLIES 7
Telles
(To:Rick-Stanley)
Hi, Rick!
  I download the lastest version of a VM (12.0.2.0 Rev1) int PTC data base:
 https://extranet.ptc.com/sites/TDD/SitePages/VMDownloadInfo.aspx
  And in the documentation is mentioned this version for TW ir 9.2:
Tks for helping.
Rafael Telles.
slangley
23-Emerald II
(To:Telles)
Hi @Telles
It sounds like you've resolved your issue.  If so, please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
Telles
(To:slangley)
Hi, Sharon.
  I´m not resolved the problema. This project has stop until I communicate my devices with TX, but the trainning than I don´t found it.
slangley
23-Emerald II
(To:slangley)
Hi @Telles.
Did you upgrade ThingWorx to 9.2?  Who provided this link?  Possibly they can provide some guidance.
Regards.
--Sharon
Telles
(To:slangley)
Hi!
This VM is avaible in PTC platform for custumers.
Regards.
Telles.
Telles
(To:Telles)
I keep going with studeis using the nem VM lanched last mouth
