Hi!
How can I call any service in the mashup if it is not created under a Thing?
@PPrasad_IoT18 You can always call service which could be part of Data Tables, Template, etc apart from under Thing. Request to provide more details and elaborate your use case .
-Durgesh
Can you explain that a little more, what service are you trying to call?
Almost the whole model is available as a Rest API call, which means you can call it as a service in a mashup.
I do want to add that some of these services should never be directly exposed in a mashup (like CreateThing or AddThingShape), these types of services should be wrapped (and therefor will reside within a Thing) so that proper security, validation and error handling can be applied.
