Hi, Here is the usecase:
I have to transfer a zip file from thingworx repository to remote edge and vice versa, for data exchange (using SDK). Typical payload size is nearly 2 GB and the frequency is once in day or on-demand.
What is the maximum file size that will be supported by Thingworx, without any data loss. What is the suggested internet bandwidth?
FileTransferSubsystem has a configurable parameter as
Hi @DivyaMalika.
If the previous response allowed you to resolve your issue, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
