Menu bar widget, items only selected on click
oskarberntorp
We have a mashup where we are navigating between some of the items in the menu with the help of different clicks in other mashups (the navigateion function).
When navigating this way, the menu item that you are on are not being selected. The menu items are neither selected when refreshing the browser window.
I have found out that the items are only selected when directly clicking them.
So my question is, is there a way to select menu items programatically, if not, can someone explain what are triggeringt the selection in the first place?
From what I can tell the selected attribute is added to the item.
Kind Regards
Oskar Berntorp
oskarberntorp
(To:wcui)
Hi @wcui,
I have been in contact with the support, there is currently no way to affect the highlighting in the way desired.
Kind Regards
Oskar Berntorp
@oskarberntorp can you share a simple demo so we can get to know the mashup configuration?
oskarberntorp
(To:wcui)
Hi @wcui,
Kind Regards
Oskar Berntorp
